跳转到主内容
HP EliteBook x360 1030 G3 Solid State Drive Replacement
你所需要的
  1. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Solid State Drive Replacement: 步骤 2 中的图像 1,1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: 步骤 3 中的图像 1,2 HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: 步骤 3 中的图像 2,2
    • Lift the black tape covering the solid state drive.
  4. HP EliteBook x360 1030 G3 Solid State Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the 2.4 mm screw using a Phillips #00 screwdriver.
  5. HP EliteBook x360 1030 G3 Solid State Drive Replacement: 步骤 5 中的图像 1,1
    • Slide the solid state drive to the left and out of its port.
    • Be careful when removing the solid state drive as bending any of the pins may render it unusable.
结论
3等其他人完成本指南。
Pablo Arriola
于04/22/19注册
504 声望
创作了3篇指南
团队
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G9
4 名成员
创作了16篇指南
3条评论
Which SSD is compatible with this computer?
Trinayaan Hariharan - 回复
Very nice its clear
Fuad Gugsa - 回复
J'ai un problème de son
Sallpape - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 104
总计 5,638
