跳转到主内容
HP EliteBook x360 1030 G3 Power Button Replacement
你所需要的
  1. HP EliteBook x360 1030 G3 Power Button Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 2 中的图像 1,1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Power Button Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 4 中的图像 1,2 HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 4 中的图像 2,2
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 5 中的图像 1,1
    • Gently lift the battery out of its place.
  6. HP EliteBook x360 1030 G3 Power Button Replacement, Fan: 步骤 6 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the four 3.5 mm screws near the middle of the fan assembly.
    • Use the same screwdriver to remove the remaining five 3.9 mm screws.
  7. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 7 中的图像 1,3 HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 7 中的图像 2,3 HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 7 中的图像 3,3
    • Before pulling the fan out, identify the two wires that are connected to the fan and to the motherboard.
    • For each, use plastic opening tool to lift the black wire housing upward out of its port.
    • Be sure not to pull the wires; doing so may cause damage.
  8. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 8 中的图像 1,2 HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 8 中的图像 2,2
    • Slide the fan assembly toward you, and when the top edge of the fan is out of the vent grill, the fan is completely removed.
  9. HP EliteBook x360 1030 G3 Power Button Replacement, Solid State Drive: 步骤 9 中的图像 1,2 HP EliteBook x360 1030 G3 Power Button Replacement, Solid State Drive: 步骤 9 中的图像 2,2
    • Lift the black tape covering the solid state drive.
  10. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 10 中的图像 1,1
    • Remove the 2.4 mm screw using a Phillips #00 screwdriver.
  11. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 11 中的图像 1,1
    • Slide the solid state drive to the left and out of its port.
    • Be careful when removing the solid state drive as bending any of the pins may render it unusable.
  12. HP EliteBook x360 1030 G3 Power Button Replacement, WWAN Card: 步骤 12 中的图像 1,2 HP EliteBook x360 1030 G3 Power Button Replacement, WWAN Card: 步骤 12 中的图像 2,2
    • Detach the small wires connected to the card by lifting the ends straight upward. The wires are held in place by friction and should pop right off.
    • These wires should be handled carefully since they're the mobile cell service/WWAN antennas.
    • Take note of which wire goes where, as mixing these cables will cause the mobile cell service/WWAN to stop working.
  13. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 13 中的图像 1,1
    • Remove the 2.4 mm screw holding the card down using a Phillips #00 screwdriver.
  14. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 14 中的图像 1,2 HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 14 中的图像 2,2
    • Carefully pull out the card by sliding it to the left.
  15. HP EliteBook x360 1030 G3 Power Button Replacement, Motherboard: 步骤 15 中的图像 1,1
    • Remove the single 5 mm screw holding the HDMI port cover in place using a Phillips #0 screwdriver.
  16. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 16 中的图像 1,1
    • Lift and remove the HDMI port cover.
  17. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 17 中的图像 1,1
    • Disconnect the red and blue display wires using an iFixit opening tool.
  18. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 18 中的图像 1,1
    • Detach the display wire connector using a nylon spudger. Repeat on the other side.
  19. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 19 中的图像 1,1
    • Flip up the five white wire clips and the single black clip using an iFixit opening tool.
    • Detach the wires connected to the motherboard.
    • Remove the two 5 mm screws that hold the motherboard in place with a Phillips #1 screwdriver.
  20. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 20 中的图像 1,1
    • Push in the SD card slot.
  21. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 21 中的图像 1,1
    • Remove the SD card slot.
  22. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 22 中的图像 1,1
    • Carefully remove the motherboard from the device by sliding it away from the laptop hinge and lifting upwards. Pull the blue sticky foam off of the back of the motherboard.
  23. HP EliteBook x360 1030 G3 Power Button Replacement, Power Button: 步骤 23 中的图像 1,1
    • Remove the two black rubber covers.
    • Remove the two 5 mm screws beneath the rubber covers using a Phillips #0 screwdriver.
  24. HP EliteBook x360 1030 G3 Power Button Replacement: 步骤 24 中的图像 1,1
    • Take out the power button.
结论
另外一个人完成了本指南。
Mal Wittmer
于07/13/23注册
103 声望
撰写一个指南
团队
IUPUI, Team 2-2, Harley Summer 2023 IUPUI, Team 2-2, Harley Summer 2023 的会员
IUPUI-HARLEY-SU23S2G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 55
总计 731
