简介
This guide shows how to replace the power button in the HP EliteBook x360 1030 G3. A power button that doesn't work makes the computer useless, as it won't turn on. Replacing it can allow you to extend the life of your computer.
你所需要的
Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
Remove the remaining four 7.3 mm screws using the same screwdriver.
Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
Detach the small wires connected to the card by lifting the ends straight upward. The wires are held in place by friction and should pop right off.
Remove the single 5 mm screw holding the HDMI port cover in place using a Phillips #0 screwdriver.
Remove the two black rubber covers.
Remove the two 5 mm screws beneath the rubber covers using a Phillips #0 screwdriver.
另外一个人完成了本指南。
