跳转到主内容
HP EliteBook x360 1030 G3 Bottom Cover Replacement
你所需要的
  1. HP EliteBook x360 1030 G3 Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Bottom Cover Replacement: 步骤 2 中的图像 1,1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
结论
2等其他人完成本指南。
Shea Charkowsky
于04/15/19注册
816 声望
创作了3篇指南
团队
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G9
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 32
过去 30 天: 78
总计 6,489
