当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Be sure to power off and unplug your device before you begin your repair.
Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
Remove the remaining four 7.3 mm screws using the same screwdriver.
Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
The plastic fastening may make cracking sounds when separating, but this is normal.
Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
Be sure to keep the screws organized because they will be reused for the next battery installation.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
