跳转到主内容
HP EliteBook x360 1030 G3 Battery Replacement
你所需要的
  1. HP EliteBook x360 1030 G3 Battery Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Battery Replacement: 步骤 2 中的图像 1,1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Battery Replacement: 步骤 4 中的图像 1,2 HP EliteBook x360 1030 G3 Battery Replacement: 步骤 4 中的图像 2,2
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Battery Replacement: 步骤 5 中的图像 1,1
    • Gently lift the battery out of its place.
结论
8等其他人完成本指南。
Pablo Arriola
于04/22/19注册
504 声望
创作了3篇指南
团队
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G9
4 名成员
创作了16篇指南
4条评论
Thanks, it is very useful.
Mohamed Wafi Aljunaedi - 回复
Looks easy and do you know if the pc can work without battery, only with charger?
Sam Uel - 回复
Thank you. very useful.
mustapha ELABED - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 39
过去 30 天: 185
总计 11,523
