跳转到主内容
HP EliteBook 8530w Hard Drive Replacement
你所需要的
  1. HP EliteBook 8530w Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP EliteBook 8530w Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the laptop off then place it down so that the back is facing up.
    • Slide the battery release switch to the left and hold it there.
  2. HP EliteBook 8530w Hard Drive Replacement: 步骤 2 中的图像 1,2 HP EliteBook 8530w Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
    • Once the battery is removed from the laptop, you may release the switch.
    • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
  3. HP EliteBook 8530w Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Remove the two screws from the hard drive cover using a Phillips #00 screwdriver.
  4. HP EliteBook 8530w Hard Drive Replacement: 步骤 4 中的图像 1,2 HP EliteBook 8530w Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Use a finger or spudger to lift the edge of the hard drive cover that was screwed down.
    • Remove the cover.
  5. HP EliteBook 8530w Hard Drive Replacement: 步骤 5 中的图像 1,3 HP EliteBook 8530w Hard Drive Replacement: 步骤 5 中的图像 2,3 HP EliteBook 8530w Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Slide the hard drive to the left to disconnect it from the connector on the right side.
    • Pull the hard drive up and out from the laptop.
    • These images show a piece of cardboard as a stand in for a missing hard drive.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 22
总计 772
