跳转到主内容
HP EliteBook 850 G5 Battery Replacement
你所需要的
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 850 G5 Battery Replacement, Remove the bottom cover screws: 步骤 2 中的图像 1,1
    • Loosen the eight captive screws that secure the bottom cover.
    • Loosen the two inset captive screws that secure the bottom cover.
  2. HP EliteBook 850 G5 Battery Replacement, Remove the bottom cover: 步骤 3 中的图像 1,1
    • Starting under the middle of the display, pry and lift the bottom cover off the computer. Consider using a spudger.
  3. HP EliteBook 850 G5 Battery Replacement, Disconnect the battery: 步骤 4 中的图像 1,1
    • Disconnect the battery cable from the system board.
    • Remove the four Torx T8 2.0×4.0 screws.
  4. HP EliteBook 850 G5 Battery Replacement, Remove the battery: 步骤 5 中的图像 1,1
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
结论
To replace the battery & reassemble your device, follow these instructions in reverse order.
另外一个人完成了本指南。
Max Kletskov
于04/22/20注册
40,307 声望
创作了16篇指南
团队
iFixit iFixit 的会员
Staff
141 名成员
创作了17,895篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 52
过去 30 天: 258
总计 6,335
