跳转到主内容
HP EliteBook 8470p Memory/RAM Replacement
  1. HP EliteBook 8470p Memory/RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
    • If the battery is “swollen” or the shape is irregular, stop whatever you are doing and allow the battery to slowly discharge itself before removing it from the laptop casing. Click the link to learn how to replace and dispose of a “swollen” battery, What to do with a swollen battery.
  2. HP EliteBook 8470p Memory/RAM Replacement: 步骤 2 中的图像 1,1
    • Slide the battery latch positioned to the right over to the right side. Hold it there.
  3. HP EliteBook 8470p Memory/RAM Replacement: 步骤 3 中的图像 1,1
    • With the latch opened, pull the battery out of its socket firmly.
    • There will likely be some resistance. However, if you find it to be excessive, the latch may not be properly opened.
  4. HP EliteBook 8470p Memory/RAM Replacement, Case/Service Cover: 步骤 4 中的图像 1,1
    • With the laptop latch still facing away from you, slide the left release latch to the left.
    • Some models may have a screw installed on this latch, if so, be sure to remove it first to avoid damaging the latch.
  5. HP EliteBook 8470p Memory/RAM Replacement: 步骤 5 中的图像 1,2 HP EliteBook 8470p Memory/RAM Replacement: 步骤 5 中的图像 2,2
    • Slide the door away from you, toward the opening latch.
    • Lift the door upwards away from the computer.
    • CAUTION: Before removing the memory module, update to the latest BIOS. Failure to do so could result in various system problems.
  6. HP EliteBook 8470p Memory/RAM Replacement: 步骤 7 中的图像 1,1
    • Spread the retaining tabs on either side of the memory module to release the module.
  7. HP EliteBook 8470p Memory/RAM Replacement: 步骤 8 中的图像 1,2 HP EliteBook 8470p Memory/RAM Replacement: 步骤 8 中的图像 2,2
    • Remove the memory module by pulling the module away from the slot at an angle.
  8. HP EliteBook 8470p Memory/RAM Replacement: 步骤 9 中的图像 1,3 HP EliteBook 8470p Memory/RAM Replacement: 步骤 9 中的图像 2,3 HP EliteBook 8470p Memory/RAM Replacement: 步骤 9 中的图像 3,3
    • Note that the device does have two memory slots. The top slot houses the the expansion memory and the bottom slot houses the primary memory.
    • Repeat the previous steps if there is an expansion memory card
结论
另外一个人完成了本指南。
Bryce Martin
于10/25/22注册
122 声望
撰写一个指南
团队
UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 的会员
UMASSD-SINCLAIRE-F22S5G3
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 32
总计 635
