跳转到主内容
HP EliteBook 8470p Fan Replacement
你所需要的
  1. HP EliteBook 8470p Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
    • If the battery is “swollen” or the shape is irregular, stop whatever you are doing and allow the battery to slowly discharge itself before removing it from the laptop casing. Click the link to learn how to replace and dispose of a “swollen” battery, What to do with a swollen battery.
  2. HP EliteBook 8470p Fan Replacement: 步骤 2 中的图像 1,1
    • Slide the battery latch positioned to the right over to the right side. Hold it there.
  3. HP EliteBook 8470p Fan Replacement: 步骤 3 中的图像 1,1
    • With the latch opened, pull the battery out of its socket firmly.
    • There will likely be some resistance. However, if you find it to be excessive, the latch may not be properly opened.
  4. HP EliteBook 8470p Fan Replacement, Case/Service Cover: 步骤 4 中的图像 1,1
    • With the laptop latch still facing away from you, slide the left release latch to the left.
    • Some models may have a screw installed on this latch, if so, be sure to remove it first to avoid damaging the latch.
  5. HP EliteBook 8470p Fan Replacement: 步骤 5 中的图像 1,2 HP EliteBook 8470p Fan Replacement: 步骤 5 中的图像 2,2
    • Slide the door away from you, toward the opening latch.
    • Lift the door upwards away from the computer.
  6. HP EliteBook 8470p Fan Replacement, Fan: 步骤 6 中的图像 1,2 HP EliteBook 8470p Fan Replacement, Fan: 步骤 6 中的图像 2,2
    • Disconnect the fan cable located directly to the right of the fan.
    • Hold the cable by the head of it and pull firmly, do not pull by the wires, as you may damage the cable.
  7. HP EliteBook 8470p Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the 5 mm Phillips #00screws to the bottom-left of the fan.
    • Remove the captive screw positioned to the top-right of the fan with a Phillips #00 screwdriver.
  8. HP EliteBook 8470p Fan Replacement: 步骤 8 中的图像 1,1
    • Lift the right side of the fan and slide it out from below the edge of the case.
    • Lift up on the fan and remove.
结论
另外一个人完成了本指南。
Owen Bangs
于10/25/22注册
656 声望
创作了5篇指南
团队
UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 的会员
UMASSD-SINCLAIRE-F22S5G3
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 35
总计 493
