跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
HP EliteBook 8440p Keyboard Replacement
你所需要的
  1. HP EliteBook 8440p Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 HP EliteBook 8440p Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 HP EliteBook 8440p Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Before you begin, unplug all cables and devices from the laptop.
    • Lay the laptop on its cover.
  2. HP EliteBook 8440p Keyboard Replacement: 步骤 2 中的图像 1,2 HP EliteBook 8440p Keyboard Replacement: 步骤 2 中的图像 2,2
    • Release the battery by pulling the battery tab to the left.
    • Remove the battery.
    • The battery is already removed in the reference image.
  3. HP EliteBook 8440p Keyboard Replacement: 步骤 3 中的图像 1,3 HP EliteBook 8440p Keyboard Replacement: 步骤 3 中的图像 2,3 HP EliteBook 8440p Keyboard Replacement: 步骤 3 中的图像 3,3
    • With a Phillips-head screwdriver, unscrew the three screws marked with the keyboard icon.
    • Do not remove the screws from the casing; they are built to stay in when loose.
  4. HP EliteBook 8440p Keyboard Replacement: 步骤 4 中的图像 1,3 HP EliteBook 8440p Keyboard Replacement: 步骤 4 中的图像 2,3 HP EliteBook 8440p Keyboard Replacement: 步骤 4 中的图像 3,3
    • Turn the laptop over and open the cover.
    • Lift the keyboard gently with a forward and upward motion.
    • Rest the keyboard over the touch pad.
    • When reassembling, line up the tabs at the keyboard's base with the casing's slots and reverse the motion.
  5. HP EliteBook 8440p Keyboard Replacement: 步骤 5 中的图像 1,1
    • Using a spudger or flat-head screwdriver, pull up the tabs at the black ribbon cable's sides to unlock the cable.
  6. HP EliteBook 8440p Keyboard Replacement: 步骤 6 中的图像 1,2 HP EliteBook 8440p Keyboard Replacement: 步骤 6 中的图像 2,2
    • Pull the black ribbon cable out of its slot.
  7. HP EliteBook 8440p Keyboard Replacement: 步骤 7 中的图像 1,1
    • Using a spudger or flat-head screwdriver, pull up the tabs at the white ribbon cable's sides to unlock the cable.
  8. HP EliteBook 8440p Keyboard Replacement: 步骤 8 中的图像 1,2 HP EliteBook 8440p Keyboard Replacement: 步骤 8 中的图像 2,2
    • Pull the white ribbon cable out of its slot.
  9. HP EliteBook 8440p Keyboard Replacement: 步骤 9 中的图像 1,1
    • Remove the keyboard from the laptop.
结论
21等其他人完成本指南。
团队
Cal Poly, Team 10-2, Green Fall 2015 Cal Poly, Team 10-2, Green Fall 2015 的会员
CPSU-GREEN-F15S10G2
3 名成员
创作了3篇指南
5条评论
The top of the keyboard has locking tabs that need to be pulled back towards the keyboard center or it won't come out. They hold the replacement keyboard in place long enough to get the screws into it.
Robert Taylor - 回复
But you don’t need to remove the battery.
Jakub Daszkiewicz - 回复
Taking it out was easy, putting a new one in- just impossible, brackets very brittle and cracking. Had to give it to the shop to fix it.
zbig j - 回复
Perfect guide except for keyboard tabs mentioned in comment from Robert Taylor! Well done!
Dave Tennant - 回复
PERFECT! It took me 15 minutes to replace the keyboard!
Victor Torkornoo - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 49
总计 17,643
