跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
HP EliteBook 840 G5 Back Cover Replacement
你所需要的
  1. HP EliteBook 840 G5 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,2 HP EliteBook 840 G5 Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use a Phillips #1 screwdriver to undo the five screws. The top three screws are 10 mm and the two side screws are 7 mm.
    • Unscrew the bottom three screws using the same screwdriver.
    • The bottom Phillips #1 screws don't remove from the back plate, but do need to be unscrewed.
    • Some models have a slightly different screw configuration, shown in the second photo.
  2. HP EliteBook 840 G5 Back Cover Replacement: 步骤 2 中的图像 1,3 HP EliteBook 840 G5 Back Cover Replacement: 步骤 2 中的图像 2,3 HP EliteBook 840 G5 Back Cover Replacement: 步骤 2 中的图像 3,3
    • Turn computer so that the hinged side is facing up.
    • Use the plastic opening tool to pry open the back plate.
    • Drag the plastic opening tool along the edge from left to right and use a second opening tool to pry open the top right corner.
    • Repeat the 3rd step for the other side.
    • Repeat on Left and Right sides of the system. There are two points in the middle (on the left and right sides of the center screw) that will release with slight lifting pressure.
    • You should be able to hear a pop when prying open the corners.
  3. HP EliteBook 840 G5 Back Cover Replacement: 步骤 3 中的图像 1,1
    • Grab the back plate and separate it slowly away from the device.
    • No wiring is connected to the back plate. Separate with caution, as there are electric components on the inside.
结论
To reassemble your device, follow these instructions in reverse order. This step is critical, as it is the beginning of all guides to access the internal of the computer.
6等其他人完成本指南。
团队
Cal Poly, Team S25-G13, Maness Spring 2018 Cal Poly, Team S25-G13, Maness Spring 2018 的会员
CPSU-MANESS-S18S25G13
4 名成员
创作了18篇指南
2条评论
vous auriez le numero de piece a commander , je ne le trouve nul part
F H - 回复
Thank you so much for this tutorial! I was able to remove my bloated battery and replace it without taking the notebook into a repair shop. I ordered the screwdrivers on Amazon and my new battery and the screwdrivers arrived today. Job done! :)
Fiona Fars - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 58
过去 30 天: 229
总计 27,359
