跳转到主内容
HP EliteBook 745 G4 Battery Replacement
你所需要的
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 745 G4 Battery Replacement, Remove the rubber plugs: 步骤 2 中的图像 1,1
    • Remove the 10 rubber plugs from the bottom cover.
    • Remove the SD card blank from the bottom cover.
  2. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: 步骤 3 中的图像 1,2 HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: 步骤 3 中的图像 2,2
    • Remove the 10 Phillips PM2.5x5.0 screws in the following order.
    • After you remove the PM2.5×5.0 screws, remove the PM2.0×7.0 screw.
  3. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover: 步骤 4 中的图像 1,1
    • Pry up on the top (near the display hinge) of the bottom cover to disengage it from the computer. Consider using a spudger.
  4. HP EliteBook 745 G4 Battery Replacement, Remove the battery: 步骤 5 中的图像 1,1
    • Loosen the two captive screws and remove the battery from the computer
结论
To replace the battery & reassemble your device, follow these instructions in reverse order.
4等其他人完成本指南。
Max Kletskov
于04/22/20注册
40,850 声望
创作了16篇指南
团队
The Home Depot The Home Depot 的会员
Community
18,020 名成员
创作了140篇指南
2条评论
you forgot to put the instructions for after the battery is installed when you boot it up You’ll get non-HP battery detected asking you to press enter on every boot. How is this problem fixed?
Richard B - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 41
总计 1,676
