跳转到主内容
HP EliteBook 745 G2 RAM Chip Replacement
你所需要的
  1. HP EliteBook 745 G2 RAM Chip Replacement, Battery: 步骤 1 中的图像 1,1
    • Gently place the laptop down on a suitable workplace with the back of the laptop facing up
  2. HP EliteBook 745 G2 RAM Chip Replacement: 步骤 2 中的图像 1,2 HP EliteBook 745 G2 RAM Chip Replacement: 步骤 2 中的图像 2,2
    • Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
  3. HP EliteBook 745 G2 RAM Chip Replacement: 步骤 3 中的图像 1,2 HP EliteBook 745 G2 RAM Chip Replacement: 步骤 3 中的图像 2,2
    • Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
  4. HP EliteBook 745 G2 RAM Chip Replacement, RAM Chip: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
  5. HP EliteBook 745 G2 RAM Chip Replacement: 步骤 5 中的图像 1,1
    • Using the spudger, gently press down on the tabs holding the chip to release it. Repeat this step for the other chip.
  6. HP EliteBook 745 G2 RAM Chip Replacement: 步骤 6 中的图像 1,1
    • Grab the chip and lift it away from the laptop at a 45 degree angle.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 532
