跳转到主内容
HP EliteBook 745 G2 Hard Drive Replacement
你所需要的
  1. HP EliteBook 745 G2 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Gently place the laptop down on a suitable workplace with the back of the laptop facing up
  2. HP EliteBook 745 G2 Hard Drive Replacement: 步骤 2 中的图像 1,2 HP EliteBook 745 G2 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
  3. HP EliteBook 745 G2 Hard Drive Replacement: 步骤 3 中的图像 1,2 HP EliteBook 745 G2 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
  4. HP EliteBook 745 G2 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • The hard drive is located to the left of the battery. To remove the hard drive firmly pull to the right until the drive is free from its attachment port.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 21
总计 1,763
