跳转到主内容
HP EliteBook 745 G2 Cooling System Replacement
你所需要的
  1. HP EliteBook 745 G2 Cooling System Replacement, Battery: 步骤 1 中的图像 1,1
    • Gently place the laptop down on a suitable workplace with the back of the laptop facing up
  2. HP EliteBook 745 G2 Cooling System Replacement: 步骤 2 中的图像 1,2 HP EliteBook 745 G2 Cooling System Replacement: 步骤 2 中的图像 2,2
    • Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
  3. HP EliteBook 745 G2 Cooling System Replacement: 步骤 3 中的图像 1,2 HP EliteBook 745 G2 Cooling System Replacement: 步骤 3 中的图像 2,2
    • Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
  4. HP EliteBook 745 G2 Cooling System Replacement, Cooling System: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
  5. HP EliteBook 745 G2 Cooling System Replacement: 步骤 5 中的图像 1,2 HP EliteBook 745 G2 Cooling System Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips #0, remove all seven of the 1.5 mm screws on the black plastic housing. Once all the screws are removed lift the plastic cover away.
    • Remove the SD card slot cover and remove the 1.5 mm Phillips #0 screw located in the slot.
  6. HP EliteBook 745 G2 Cooling System Replacement: 步骤 6 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the remaining five 1.5 mm screws holding the cooling system and fan to the motherboard.
  7. HP EliteBook 745 G2 Cooling System Replacement: 步骤 7 中的图像 1,1
    • Lift the fan and cooling system upwards until they become free from the computer.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 36
总计 2,159
