跳转到主内容
HP EliteBook 745 G2 Battery Replacement
你所需要的
  1. HP EliteBook 745 G2 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Gently place the laptop down on a suitable workplace with the back of the laptop facing up
  2. HP EliteBook 745 G2 Battery Replacement: 步骤 2 中的图像 1,2 HP EliteBook 745 G2 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
  3. HP EliteBook 745 G2 Battery Replacement: 步骤 3 中的图像 1,2 HP EliteBook 745 G2 Battery Replacement: 步骤 3 中的图像 2,2
    • Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 32
总计 1,133
