跳转到主内容
HP EliteBook 1050 G1 SSD Replacement
你所需要的
  1. HP EliteBook 1050 G1 SSD Replacement, SSD: 步骤 1 中的图像 1,2 HP EliteBook 1050 G1 SSD Replacement, SSD: 步骤 1 中的图像 2,2
    • Remove the two 5.5mm screws with a Torx T8 driver.
    • Remove the five 8.7mm screws with a Torx T8 driver.
    • Remove the two 6.6mm screws with a Torx T8 driver.
    • Pry open the backplate with a Jimmy.
  2. HP EliteBook 1050 G1 SSD Replacement: 步骤 2 中的图像 1,1
    • Remove the two 1.9mm screws from the SSDs with a Phillips #0 driver.
  3. HP EliteBook 1050 G1 SSD Replacement: 步骤 3 中的图像 1,2 HP EliteBook 1050 G1 SSD Replacement: 步骤 3 中的图像 2,2
    • With the screws removed, the SSD should pop up off of the board below.
    • Disconnect the two PCIe SSDs by sliding them out of each port.
    • When re-inserting the new SSDs make sure the white specs labels are facing up.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 517
