跳转到主内容
HP EliteBook 1040 G4 Speakers Replacement
你所需要的
  1. HP EliteBook 1040 G4 Speakers Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Speakers Replacement: 步骤 2 中的图像 1,2 HP EliteBook 1040 G4 Speakers Replacement: 步骤 2 中的图像 2,2
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Speakers Replacement, Battery: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Speakers Replacement: 步骤 4 中的图像 1,2 HP EliteBook 1040 G4 Speakers Replacement: 步骤 4 中的图像 2,2
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Speakers Replacement: 步骤 5 中的图像 1,2 HP EliteBook 1040 G4 Speakers Replacement: 步骤 5 中的图像 2,2
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Speakers Replacement, Speakers: 步骤 6 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the four black 6 mm screws securing the speakers to the device.
  7. HP EliteBook 1040 G4 Speakers Replacement: 步骤 7 中的图像 1,1
    • Disconnect the pin connector from the right side of the speaker assembly.
  8. HP EliteBook 1040 G4 Speakers Replacement: 步骤 8 中的图像 1,1
    • Carefully remove the red and black wires from the black clips in between the two speakers.
  9. HP EliteBook 1040 G4 Speakers Replacement: 步骤 9 中的图像 1,1
    • Remove the speakers from the device.
结论
Hannah DiMartino
于09/28/21注册
395 声望
创作了3篇指南
团队
Clemson, Team 4-1, Hunter Fall 2021 Clemson, Team 4-1, Hunter Fall 2021 的会员
CLEM-HUNTER-F21S4G1
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 484
