跳转到主内容
HP EliteBook 1040 G4 Coin Cell Battery Replacement
你所需要的
  1. HP EliteBook 1040 G4 Coin Cell Battery  Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 步骤 2 中的图像 1,2 HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 步骤 2 中的图像 2,2
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Coin Cell Battery  Replacement, Battery: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 步骤 4 中的图像 1,2 HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 步骤 4 中的图像 2,2
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 步骤 5 中的图像 1,2 HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 步骤 5 中的图像 2,2
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Coin Cell Battery  Replacement, Coin Cell Battery: 步骤 6 中的图像 1,1
    • Carefully disconnect the pin connector from the right side of the speaker assembly.
  7. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 步骤 7 中的图像 1,2 HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 步骤 7 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the two 6 mm black screws securing the speakers to the device.
    • Lift the speakers up and out.
  8. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 步骤 8 中的图像 1,1
    • Carefully disconnect the coin cell battery cable located under the motherboard.
  9. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 步骤 9 中的图像 1,1
    • Remove the coin cell battery.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 24
总计 469
