跳转到主内容
HP Elite x2 G4 Battery Replacement
你所需要的
  1. HP Elite x2 G4 Battery Replacement, Display Assembly: 步骤 1 中的图像 1,1
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite x2 G4 Battery Replacement: 步骤 2 中的图像 1,1
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
  3. HP Elite x2 G4 Battery Replacement: 步骤 3 中的图像 1,1
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
  4. HP Elite x2 G4 Battery Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite x2 G4 Battery Replacement: 步骤 5 中的图像 1,1
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
  6. HP Elite x2 G4 Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • Remove the six 3.5 mm Phillips #1 screws that secure the battery to the display enclosure.
  7. HP Elite x2 G4 Battery Replacement: 步骤 7 中的图像 1,1
    • Carefully lift the top edge of the battery off of the alignment pins.
    • Remove the battery.
  8. HP Elite x2 G4 Battery Replacement: 步骤 8 中的图像 1,1
    • Slide the bottom edge out from retention tabs on the display enclosure and remove.
结论
另外一个人完成了本指南。
Goncalo Felix
于10/25/22注册
325 声望
创作了3篇指南
团队
UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 的会员
UMASSD-SINCLAIRE-F22S4G4
5 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 29
过去 30 天: 156
总计 1,257
