跳转到主内容
HP Elite x2 G1 1012 WWAN Card Replacement
你所需要的
  1. HP Elite x2 G1 1012 WWAN Card Replacement, Display: 步骤 1 中的图像 1,1
    • Be sure to power off and unplug your device before you begin your repair.
    • With the screen face down, lift up the stand as far as it goes.
    • Make sure not to force it past the resting point.
  2. HP Elite x2 G1 1012 WWAN Card Replacement: 步骤 2 中的图像 1,2 HP Elite x2 G1 1012 WWAN Card Replacement: 步骤 2 中的图像 2,2
    • Use a T5 driver to remove the six screws on the back of the tablet.
  3. HP Elite x2 G1 1012 WWAN Card Replacement: 步骤 3 中的图像 1,1
    • After removing the screws, delicately close the stand.
    • Flip the tablet on its back so that the screen is facing up.
  4. HP Elite x2 G1 1012 WWAN Card Replacement: 步骤 4 中的图像 1,2 HP Elite x2 G1 1012 WWAN Card Replacement: 步骤 4 中的图像 2,2
    • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
    • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
  5. HP Elite x2 G1 1012 WWAN Card Replacement: 步骤 5 中的图像 1,3 HP Elite x2 G1 1012 WWAN Card Replacement: 步骤 5 中的图像 2,3 HP Elite x2 G1 1012 WWAN Card Replacement: 步骤 5 中的图像 3,3
    • Remove the tape on the lower left side of the screen.
    • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
  6. HP Elite x2 G1 1012 WWAN Card Replacement: 步骤 6 中的图像 1,2 HP Elite x2 G1 1012 WWAN Card Replacement: 步骤 6 中的图像 2,2
    • Disconnect the flex cable from the device using the spudger.
    • Remove the Display Assembly from the device.
  7. HP Elite x2 G1 1012 WWAN Card Replacement, WWAN Card: 步骤 7 中的图像 1,2 HP Elite x2 G1 1012 WWAN Card Replacement, WWAN Card: 步骤 7 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the screw from the left hand side of the board.
  8. HP Elite x2 G1 1012 WWAN Card Replacement: 步骤 8 中的图像 1,3 HP Elite x2 G1 1012 WWAN Card Replacement: 步骤 8 中的图像 2,3 HP Elite x2 G1 1012 WWAN Card Replacement: 步骤 8 中的图像 3,3
    • Remove the two black wires that are connected to the board with a pair of tweezers.
  9. HP Elite x2 G1 1012 WWAN Card Replacement: 步骤 9 中的图像 1,1
    • Use the spudger to lift the board up slightly.
    • Continue to lift and slide the WWAN card until it is completely removed from the device.
结论
Colin Mika
于04/19/18注册
943 声望
创作了6篇指南
团队
Cal Poly, Team S24-G7, Maness Spring 2018 Cal Poly, Team S24-G7, Maness Spring 2018 的会员
CPSU-MANESS-S18S24G7
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 1,339
