当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Be sure to power off and unplug your device before you begin your repair.
With the screen face down, lift up the stand as far as it goes.
Make sure not to force it past the resting point.
After removing the screws, delicately close the stand.
Flip the tablet on its back so that the screen is facing up.
Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
Remove the tape on the lower left side of the screen.
Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
Slightly lift the card up and then remove the SSD card from the device.
As you slide it out, make sure it gets unplugged from the port. Do not continue to tug on a stuck port.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
