跳转到主内容
HP Elite x2 G1 1012 Battery Replacement
你所需要的
  1. HP Elite x2 G1 1012 Battery Replacement, Display: 步骤 1 中的图像 1,1
    • Be sure to power off and unplug your device before you begin your repair.
    • With the screen face down, lift up the stand as far as it goes.
    • Make sure not to force it past the resting point.
  2. HP Elite x2 G1 1012 Battery Replacement: 步骤 2 中的图像 1,2 HP Elite x2 G1 1012 Battery Replacement: 步骤 2 中的图像 2,2
    • Use a T5 driver to remove the six screws on the back of the tablet.
  3. HP Elite x2 G1 1012 Battery Replacement: 步骤 3 中的图像 1,1
    • After removing the screws, delicately close the stand.
    • Flip the tablet on its back so that the screen is facing up.
  4. HP Elite x2 G1 1012 Battery Replacement: 步骤 4 中的图像 1,2 HP Elite x2 G1 1012 Battery Replacement: 步骤 4 中的图像 2,2
    • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
    • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
  5. HP Elite x2 G1 1012 Battery Replacement: 步骤 5 中的图像 1,3 HP Elite x2 G1 1012 Battery Replacement: 步骤 5 中的图像 2,3 HP Elite x2 G1 1012 Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the tape on the lower left side of the screen.
    • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
  6. HP Elite x2 G1 1012 Battery Replacement: 步骤 6 中的图像 1,2 HP Elite x2 G1 1012 Battery Replacement: 步骤 6 中的图像 2,2
    • Disconnect the flex cable from the device using the spudger.
    • Remove the Display Assembly from the device.
  7. HP Elite x2 G1 1012 Battery Replacement, Battery: 步骤 7 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the seven screws holding the battery in place.
    • Five 1.6x2.5 mm and two 1.6x2 screws should be on the battery.
  8. HP Elite x2 G1 1012 Battery Replacement: 步骤 8 中的图像 1,2 HP Elite x2 G1 1012 Battery Replacement: 步骤 8 中的图像 2,2
    • Disconnect the red, white, and black wires and remove the battery from the device.
    • Make sure to properly dispose of the dead battery.
结论
7等其他人完成本指南。
Colin Mika
于04/19/18注册
943 声望
创作了6篇指南
团队
Cal Poly, Team S24-G7, Maness Spring 2018 Cal Poly, Team S24-G7, Maness Spring 2018 的会员
CPSU-MANESS-S18S24G7
4 名成员
创作了6篇指南
5条评论
Thanks a lot for the information!
Santi Costa - 回复
Thanks for the help. Successfully change my battery.
Christopher Rath - 回复
One problem that people might run into is the device not recognizing the battery firmware if it is an aftermarket battery and not a genuine HP one. Where the device will work but only if it is plugged into the charger. It even shows the battery charging but very slowly. If you disconnect the charger the device will instantly shut off. What is the fix for that?
Adam Stansbery - 回复
Why must the flex cable be disconnected? If you are able to secure the screen in proper position it does not appear that it would interfere with the battery change.
Bart Farkus - 回复
Na vervanging batterij aangesloten op charger, witte led knippert enkele malen en gaat dan uit. De batterij indicator in windows geeft niet aan dat er geladen wordt. Wat zou de oorzaak kunnen zijn?
Tim Röttger - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 108
总计 9,976
