跳转到主内容
HP Elite x2 1012 G2 Wi-Fi Card Replacement
你所需要的
  1. HP Elite x2 1012 G2 Wi-Fi Card Replacement, Screen: 步骤 1 中的图像 1,1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 2 中的图像 1,3 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 2 中的图像 2,3 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 2 中的图像 3,3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 3 中的图像 1,2 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 3 中的图像 2,2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 4 中的图像 1,1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 5 中的图像 1,3 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 5 中的图像 2,3 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 5 中的图像 3,3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 6 中的图像 1,2 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 6 中的图像 2,2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 7 中的图像 1,1
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 8 中的图像 1,3 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 8 中的图像 2,3 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 8 中的图像 3,3
    • Detach the two wire connections on the upper right of the wi-fi card by hand.
  9. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 9 中的图像 1,2 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 9 中的图像 2,2
    • Use a Phillips 2mm screwdriver to remove the single M2 2.0x2.0 screw holding the wi-fi card in place. Turn the screwdriver counterclockwise to remove the screw.
  10. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 10 中的图像 1,2 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 步骤 10 中的图像 2,2
    • Slide the wi-fi card out by hand, lifting the card up and out of the device.
    • If it doesn't come out immediately, slowly wiggle the card side to side until it slides out of its connector.
结论
3等其他人完成本指南。
Nathan Diekema
于04/18/18注册
279 声望
撰写一个指南
团队
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G5
4 名成员
创作了13篇指南
一条评论
Hi is it to upgrade the broadband to support 4g lte? Mine unit when inserted 4g data sim card, only can run edge signal. Spec of the broadband is hp hs3210 hspa+
Kenny Liew - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 44
总计 2,041
