跳转到主内容
HP Elite x2 1012 G2 Screen Replacement
你所需要的
  1. HP Elite x2 1012 G2 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Screen Replacement: 步骤 2 中的图像 1,3 HP Elite x2 1012 G2 Screen Replacement: 步骤 2 中的图像 2,3 HP Elite x2 1012 G2 Screen Replacement: 步骤 2 中的图像 3,3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Screen Replacement: 步骤 3 中的图像 1,2 HP Elite x2 1012 G2 Screen Replacement: 步骤 3 中的图像 2,2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Screen Replacement: 步骤 4 中的图像 1,1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Screen Replacement: 步骤 5 中的图像 1,3 HP Elite x2 1012 G2 Screen Replacement: 步骤 5 中的图像 2,3 HP Elite x2 1012 G2 Screen Replacement: 步骤 5 中的图像 3,3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Screen Replacement: 步骤 6 中的图像 1,2 HP Elite x2 1012 G2 Screen Replacement: 步骤 6 中的图像 2,2
    • Remove the screen by gently lifting it off of the device.
结论
3等其他人完成本指南。
Noah Stapp
于04/18/18注册
722 声望
创作了2篇指南
团队
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G5
4 名成员
创作了13篇指南
5条评论
Where can I purchase a screen for the HP Elite x2 1012 g2?
Greg M - 回复
just completed this, VERY surprising to find a HP product with an easy install
CILLIAN BYRNE - 回复
Just finished a repair and very easy to do. Thank you!!
Richard Taylor - 回复
The touch stopped working after the replacement. Any suggestions?
el._.msn - 回复
I replaced my screen and upon turning the device on I have a black screen. Already made sure connections are all attached correctly. Tried hard reset with power and volume button down for 15 seconds. A bad new screen? Any other ideas?
iamacomputertech - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 30
过去 30 天: 130
总计 8,378
