跳转到主内容
HP Elite x2 1012 G2 Rear Facing Camera Replacement
你所需要的
  1. HP Elite x2 1012 G2 Rear Facing Camera Replacement, Screen: 步骤 1 中的图像 1,1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Rear Facing Camera Replacement: 步骤 2 中的图像 1,3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: 步骤 2 中的图像 2,3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: 步骤 2 中的图像 3,3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Rear Facing Camera Replacement: 步骤 3 中的图像 1,2 HP Elite x2 1012 G2 Rear Facing Camera Replacement: 步骤 3 中的图像 2,2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Rear Facing Camera Replacement: 步骤 4 中的图像 1,1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Rear Facing Camera Replacement: 步骤 5 中的图像 1,3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: 步骤 5 中的图像 2,3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: 步骤 5 中的图像 3,3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Rear Facing Camera Replacement: 步骤 6 中的图像 1,2 HP Elite x2 1012 G2 Rear Facing Camera Replacement: 步骤 6 中的图像 2,2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 7 中的图像 1,2 HP Elite x2 1012 G2 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 7 中的图像 2,2
    • Locate the cameras at the top center of the power and processing unit.
    • Use a Phillips #00 screwdriver to remove the single 3 mm screw.
    • Use a spudger tool to lift up the ribbon cable clamps.
    • Be careful not to crease or damage the ribbon cables or connectors.
  8. HP Elite x2 1012 G2 Rear Facing Camera Replacement: 步骤 8 中的图像 1,2 HP Elite x2 1012 G2 Rear Facing Camera Replacement: 步骤 8 中的图像 2,2
    • Remove the front-facing camera.
    • Remove the metal bracket securing the rear-facing camera.
    • Remove the rear-facing camera.
结论
WesleyEagleson
于04/06/19注册
431 声望
创作了3篇指南
团队
IUPUI, Team S13-G13, Wilson Spring 2019 IUPUI, Team S13-G13, Wilson Spring 2019 的会员
IUPUI-WILSON-S19S13G13
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 527
