跳转到主内容
HP Elite x2 1012 G2 Front Webcam Replacement
你所需要的
  1. HP Elite x2 1012 G2 Front Webcam Replacement, Screen: 步骤 1 中的图像 1,1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 2 中的图像 1,3 HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 2 中的图像 2,3 HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 2 中的图像 3,3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 3 中的图像 1,2 HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 3 中的图像 2,2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 4 中的图像 1,1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 5 中的图像 1,3 HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 5 中的图像 2,3 HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 5 中的图像 3,3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 6 中的图像 1,2 HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 6 中的图像 2,2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Front Webcam Replacement, Front Webcam: 步骤 7 中的图像 1,1
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 8 中的图像 1,3 HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 8 中的图像 2,3 HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 8 中的图像 3,3
    • Remove the wire connector to the front webcam using a plastic opening tool. Hook the tool underneath the connector and pull up and back.
  9. HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 9 中的图像 1,1
    • Remove the connector immediately to the left of the front webcam's connector. Use a plastic opening tool to gently lift the connector up and out.
  10. HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 10 中的图像 1,1
    • Remove the connector immediately to the right of the front webcam's connector. Use a plastic opening tool to gently lift the connector up and out.
  11. HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 11 中的图像 1,2 HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 11 中的图像 2,2
    • Use a Phillips screwdriver to remove the Phillips M2.0x2.0 screw to the left of the webcam. Turn the screwdriver counterclockwise to remove the screw.
  12. HP Elite x2 1012 G2 Front Webcam Replacement: 步骤 12 中的图像 1,1
    • Remove the webcam using a plastic opening tool to lift it up and off.
结论
2等其他人完成本指南。
Noah Stapp
于04/18/18注册
695 声望
创作了2篇指南
团队
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G5
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 22
总计 1,989
