跳转到主内容
HP Elite x2 1012 G2 Battery Replacement
你所需要的
  1. HP Elite x2 1012 G2 Battery Replacement, Screen: 步骤 1 中的图像 1,1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Battery Replacement: 步骤 2 中的图像 1,3 HP Elite x2 1012 G2 Battery Replacement: 步骤 2 中的图像 2,3 HP Elite x2 1012 G2 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Battery Replacement: 步骤 3 中的图像 1,2 HP Elite x2 1012 G2 Battery Replacement: 步骤 3 中的图像 2,2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Battery Replacement: 步骤 4 中的图像 1,1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Battery Replacement: 步骤 5 中的图像 1,3 HP Elite x2 1012 G2 Battery Replacement: 步骤 5 中的图像 2,3 HP Elite x2 1012 G2 Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Battery Replacement: 步骤 6 中的图像 1,2 HP Elite x2 1012 G2 Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Battery Replacement, Battery: 步骤 7 中的图像 1,1
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Battery Replacement: 步骤 8 中的图像 1,2 HP Elite x2 1012 G2 Battery Replacement: 步骤 8 中的图像 2,2
    • Remove all six Phillips 3 mm screws around the battery by rotating in the counterclockwise direction with a Phillips screwdriver.
  9. HP Elite x2 1012 G2 Battery Replacement: 步骤 9 中的图像 1,2 HP Elite x2 1012 G2 Battery Replacement: 步骤 9 中的图像 2,2
    • Remove the battery's connector by pushing both sides of the tab towards yourself with a plastic opening tool.
  10. HP Elite x2 1012 G2 Battery Replacement: 步骤 10 中的图像 1,1
    • Lift the battery out of the device.
结论
13等其他人完成本指南。
Andy Velazquez
于04/18/18注册
314 声望
撰写一个指南
团队
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G5
4 名成员
创作了13篇指南
4条评论
how do you test the battery? what voltage should it be maintaining?
scott kay - 回复
Hi, after the replacement battery
toch not working, help pls?
Parsa Aghabeikzadeh - 回复
PC not coming on, also not charging.
Abiola - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 79
过去 30 天: 416
总计 22,201
