跳转到主内容
HP Elite X2 1013 G3 Wireless Card Replacement
你所需要的
  1. HP Elite X2 1013 G3 Wireless Card Replacement, Screen: 步骤 1 中的图像 1,1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Wireless Card Replacement: 步骤 2 中的图像 1,2 HP Elite X2 1013 G3 Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Wireless Card Replacement: 步骤 3 中的图像 1,2 HP Elite X2 1013 G3 Wireless Card Replacement: 步骤 3 中的图像 2,2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Wireless Card Replacement: 步骤 4 中的图像 1,2 HP Elite X2 1013 G3 Wireless Card Replacement: 步骤 4 中的图像 2,2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Wireless Card Replacement, Battery: 步骤 5 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Wireless Card Replacement: 步骤 6 中的图像 1,1
    • Lift the battery out of the housing.
  7. HP Elite X2 1013 G3 Wireless Card Replacement, Wireless Card: 步骤 7 中的图像 1,1
    • Make sure the laptop is turned off and the battery is removed before continuing!
    • Remove the single 2 mm screw with a Phillips #00 Screwdriver.
  8. HP Elite X2 1013 G3 Wireless Card Replacement: 步骤 8 中的图像 1,1
    • Gently disconnect the single wire connector with your finger.
  9. HP Elite X2 1013 G3 Wireless Card Replacement: 步骤 9 中的图像 1,1
    • Gently lift the wireless card and firmly pull it out of the motherboard.
    • Pay attention to the orientation of the wireless card. Trying to put your replacement wireless card in the wrong way could damage the part or the connector.
结论
Kory Haydon
于04/18/19注册
259 声望
创作了2篇指南
团队
Cal Poly, Team S9-G12, Maness Spring 2019 Cal Poly, Team S9-G12, Maness Spring 2019 的会员
CPSU-MANESS-S19S9G12
4 名成员
创作了5篇指南
一条评论
Just to note, this is the WWAN (cellular/LTE) card, not the WLAN card (WiFi). The WLAN card is soldered down and not removable.
Dennis Favro - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 643
