跳转到主内容
HP Elite X2 1013 G3 Screen Replacement
你所需要的
  1. HP Elite X2 1013 G3 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Screen Replacement: 步骤 2 中的图像 1,2 HP Elite X2 1013 G3 Screen Replacement: 步骤 2 中的图像 2,2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Screen Replacement: 步骤 3 中的图像 1,2 HP Elite X2 1013 G3 Screen Replacement: 步骤 3 中的图像 2,2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Screen Replacement: 步骤 4 中的图像 1,2 HP Elite X2 1013 G3 Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the screen from the tablet.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 62
总计 1,079
