跳转到主内容
HP Elite X2 1013 G3 Camera Replacement
你所需要的
  1. HP Elite X2 1013 G3 Camera Replacement, Screen: 步骤 1 中的图像 1,1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Camera Replacement: 步骤 2 中的图像 1,2 HP Elite X2 1013 G3 Camera Replacement: 步骤 2 中的图像 2,2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Camera Replacement: 步骤 3 中的图像 1,2 HP Elite X2 1013 G3 Camera Replacement: 步骤 3 中的图像 2,2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Camera Replacement: 步骤 4 中的图像 1,2 HP Elite X2 1013 G3 Camera Replacement: 步骤 4 中的图像 2,2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Camera Replacement, Camera: 步骤 5 中的图像 1,2 HP Elite X2 1013 G3 Camera Replacement, Camera: 步骤 5 中的图像 2,2
    • Place the tip of an opening tool beneath the camera housing.
    • Slowly move the tool up and down until the camera pops off the laptop.
    • Remove the connector and lift the camera away from the laptop.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 339
