跳转到主内容
HP ENVY 5530 Front Panel Replacement
你所需要的
  1. HP ENVY 5530 Front Panel Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Lift up printer screen.
  2. HP ENVY 5530 Front Panel Replacement: 步骤 2 中的图像 1,3 HP ENVY 5530 Front Panel Replacement: 步骤 2 中的图像 2,3 HP ENVY 5530 Front Panel Replacement: 步骤 2 中的图像 3,3
    • Use the Metal Spudger from the IFIXIT Toolkit to pry the left corner of the front panel.
    • Slowly pry the front panel by sliding the Metal Spudger along the border of the front panel.
    On some printer version, you may find a single torx 10 screw under the right sticker.
    Remove it and then slide the panel to the right then to the top.
    Easy as said!
    No need to use any spudger.
    Learned it the hard way ;)
    Cecil His Mahier - 回复
  3. HP ENVY 5530 Front Panel Replacement: 步骤 3 中的图像 1,2 HP ENVY 5530 Front Panel Replacement: 步骤 3 中的图像 2,2
    • Remove the front panel by lifting each corner up.
    • Replace the front panel.
    There’s a screw undcer the model label on the right. Peel the label up right to left to expose the screw, remove the screw to lift the front panel off.
    sel full - 回复
结论
Elizabeth Surface
于08/26/15注册
1,465 声望
创作了9篇指南
团队
USF Tampa, Team 4-6, Meier Fall 2015 USF Tampa, Team 4-6, Meier Fall 2015 的会员
USFT-MEIER-F15S4G6
4 名成员
创作了18篇指南
4条评论
My HP Envy 5530 had a screw hidden beneath the label on the right side of the front panel. I used a knife to lift the label to access the screw.
rndymike - 回复
Is the front panel from a 5532 compatible with the Envy 5530?
Armando Pagan - 回复
Wish I would have seen the comment about the screw… fix your post… at least protect others from making the same mistake
Azpatch - 回复
Where does the cable go?
Victorian Lover - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 36
总计 2,197
