跳转到主内容
HP ENVY 5530 Front Panel Replacement
你所需要的
  1. HP ENVY 5530 Front Panel Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Lift up printer screen.
  2. HP ENVY 5530 Front Panel Replacement: 步骤 2 中的图像 1,3 HP ENVY 5530 Front Panel Replacement: 步骤 2 中的图像 2,3 HP ENVY 5530 Front Panel Replacement: 步骤 2 中的图像 3,3
    • Use the Metal Spudger from the IFIXIT Toolkit to pry the left corner of the front panel.
    • Slowly pry the front panel by sliding the Metal Spudger along the border of the front panel.
  3. HP ENVY 5530 Front Panel Replacement: 步骤 3 中的图像 1,2 HP ENVY 5530 Front Panel Replacement: 步骤 3 中的图像 2,2
    • Remove the front panel by lifting each corner up.
    • Replace the front panel.
结论
Elizabeth Surface
于08/26/15注册
1,465 声望
创作了9篇指南
团队
USF Tampa, Team 4-6, Meier Fall 2015 USF Tampa, Team 4-6, Meier Fall 2015 的会员
USFT-MEIER-F15S4G6
4 名成员
创作了18篇指南
4条评论
My HP Envy 5530 had a screw hidden beneath the label on the right side of the front panel. I used a knife to lift the label to access the screw.
rndymike - 回复
Is the front panel from a 5532 compatible with the Envy 5530?
Armando Pagan - 回复
Wish I would have seen the comment about the screw… fix your post… at least protect others from making the same mistake
Azpatch - 回复
Where does the cable go?
Victorian Lover - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 31
总计 2,191
