你所需要的
Shut down the laptop.
Turn it over and position it so that the display hinges face away from you.
Remove the rubber strip that is close to the display hinges.
Remove the adhesive strip along with the rubber to reveal the underlying screws.
Remove the four Phillips P1 screws that are revealed by removing the rubber strip.
Note that the second screw hole from the right is not as deep as the other three.
Using an opening tool and opening picks, separate the bottom housing plate from the rest of the chassis on the left, bottom and right edges.
Lift and remove the plate.
Remove the seven Phillips P1 screws that hold the battery in place.
Note that these battery screws have a different length than the P1 chassis screws.
Remove the black tape that is stuck to the large silver-black RAM housing.
Using both hands, bend outwards the two clips that hold the RAM module.
Remove the RAM module to the right and up.
Now insert the new RAM module, pushing it in from the right.
2等其他人完成本指南。
