简介
If the scans or copies made are not matching the desired document, replacing the scanner glass is a solution to consider. There could be a crack or scratch in the glass affecting the quality of the scanned or copied document. Follow this guide if you need to replace the scanner glass of your HP Deskjet GT-5821.
你所需要的
Open the front access panel by placing your finger in the front slot and pulling gently.
Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
3等其他人完成本指南。
