跳转到主内容
HP Deskjet GT-5821 Scanner Glass Replacement
你所需要的
  1. HP Deskjet GT-5821 Scanner Glass Replacement, Open front access panel: 步骤 1 中的图像 1,1
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. HP Deskjet GT-5821 Scanner Glass Replacement, Top Lid: 步骤 2 中的图像 1,1
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. HP Deskjet GT-5821 Scanner Glass Replacement: 步骤 3 中的图像 1,3 HP Deskjet GT-5821 Scanner Glass Replacement: 步骤 3 中的图像 2,3 HP Deskjet GT-5821 Scanner Glass Replacement: 步骤 3 中的图像 3,3
    • Remove the four 9mm T10 Torx screws on the top.
  4. HP Deskjet GT-5821 Scanner Glass Replacement: 步骤 4 中的图像 1,2 HP Deskjet GT-5821 Scanner Glass Replacement: 步骤 4 中的图像 2,2
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  5. HP Deskjet GT-5821 Scanner Glass Replacement: 步骤 5 中的图像 1,3 HP Deskjet GT-5821 Scanner Glass Replacement: 步骤 5 中的图像 2,3 HP Deskjet GT-5821 Scanner Glass Replacement: 步骤 5 中的图像 3,3
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
  6. HP Deskjet GT-5821 Scanner Glass Replacement, Remove Back Panel of Lid: 步骤 6 中的图像 1,1
    • Remove one 9mm T10 Torx screw from the back of the printer lid.
  7. HP Deskjet GT-5821 Scanner Glass Replacement: 步骤 7 中的图像 1,2 HP Deskjet GT-5821 Scanner Glass Replacement: 步骤 7 中的图像 2,2
    • Press outward on the plastic tab holding the back panel in place.
  8. HP Deskjet GT-5821 Scanner Glass Replacement: 步骤 8 中的图像 1,2 HP Deskjet GT-5821 Scanner Glass Replacement: 步骤 8 中的图像 2,2
    • Pull the back panel towards you and lift it away from the rest of the printer cover.
    • Some ribbon cables may still be inserted through the back panel. Be careful not to damage these and they should slide out easily.
  9. HP Deskjet GT-5821 Scanner Glass Replacement, Scanner Glass: 步骤 9 中的图像 1,1
    • Remove one 9mm T10 Torx screw from the white retaining tab.
  10. HP Deskjet GT-5821 Scanner Glass Replacement: 步骤 10 中的图像 1,1
    • Remove the white retaining tab.
  11. HP Deskjet GT-5821 Scanner Glass Replacement: 步骤 11 中的图像 1,1
    • To remove the scanner glass, gently push it towards you.
    • Slide glass panel until it is completely removed from printer.
    • Use caution when removing glass and be aware of any sharp edges.
结论
3等其他人完成本指南。
Kevin Raives
于01/15/13注册
93 声望
创作了2篇指南
团队
Cal Poly, Team 18-35, Regan Winter 2013 Cal Poly, Team 18-35, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G35
5 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 2,107
