跳转到主内容
HP Deskjet F4480 Paper Roller Motor Replacement
你所需要的
  1. HP Deskjet F4480 Paper Roller Motor Replacement, Open front access panel: 步骤 1 中的图像 1,1
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. HP Deskjet F4480 Paper Roller Motor Replacement, Top Lid: 步骤 2 中的图像 1,1
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 3 中的图像 1,3 HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 3 中的图像 2,3 HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 3 中的图像 3,3
    • Remove the four 9mm T10 Torx screws on the top.
  4. HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 4 中的图像 1,2 HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 4 中的图像 2,2
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  5. HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 5 中的图像 1,3 HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 5 中的图像 2,3 HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 5 中的图像 3,3
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
  6. HP Deskjet F4480 Paper Roller Motor Replacement, Paper Roller Motor: 步骤 6 中的图像 1,2 HP Deskjet F4480 Paper Roller Motor Replacement, Paper Roller Motor: 步骤 6 中的图像 2,2
    • Detach the white ribbon cable.
    • Remove the two 9mm Torx screws on either side of the white bracket.
  7. HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 7 中的图像 1,2 HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 7 中的图像 2,2
    • Remove the three black 9mm Torx screws and pull the black panel out from under the ink carriage.
  8. HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 8 中的图像 1,1
    • Remove the five 9mm Torx screws on the silver panel.
    • Pull out the silver panel.
  9. HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 9 中的图像 1,1
    • Remove the green & yellow cable and the black & white cable.
  10. HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 10 中的图像 1,1
    • Turn the printer over.
    • Locate the gap at the bottom corner near the product information sticker.
    • Reach a flat head screwdriver inside the gap and unlatch the silver tab.
    • A spudger tool is not the correct tool for this step, it has the potential to break.
    • For better visibility of the silver tab inside the gap, the use of a flashlight is recommended.
  11. HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 11 中的图像 1,2 HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 11 中的图像 2,2
    • Remove the two 9mm Torx screws in order to detach the roller assembly from the system.
  12. HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 12 中的图像 1,1
    • Remove the roller assembly from the printer case.
  13. HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 13 中的图像 1,1
    • Remove the two 6mm torx screws using a T9 Torx bit.
  14. HP Deskjet F4480 Paper Roller Motor Replacement: 步骤 14 中的图像 1,1
    • Remove the paper roller motor.
    • Replace the old motor.
结论
To reassemble your device, with the addition of a new motor, follow these instructions in reverse order.
7等其他人完成本指南。
Kevin Raives
于01/15/13注册
93 声望
创作了2篇指南
团队
Cal Poly, Team 18-35, Regan Winter 2013 Cal Poly, Team 18-35, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G35
5 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 22
总计 5,501
