跳转到主内容
HP Deskjet F4480 Ink Cartridges Replacement
  1. HP Deskjet F4480 Ink Cartridges Replacement, Open front access panel: 步骤 1 中的图像 1,1
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. HP Deskjet F4480 Ink Cartridges Replacement, Ink Cartridges: 步骤 2 中的图像 1,1
    • Slide the ink carriage until the the cartridges line up with the marked slots in the middle.
    • If the printer is on, then the carriage should have automatically slid to the middle when the front was opened. If not, ensure printer is unplugged and slide manually.
  3. HP Deskjet F4480 Ink Cartridges Replacement: 步骤 3 中的图像 1,2 HP Deskjet F4480 Ink Cartridges Replacement: 步骤 3 中的图像 2,2
    • Gently, but firmly depress the front of the ink cartridge you are removing until it is loose.
    • There may be a faint click when the cartridge comes loose.
  4. HP Deskjet F4480 Ink Cartridges Replacement: 步骤 4 中的图像 1,1
    • Gently slide out cartridge.
    • Don't make contact with the ink head. The ink likes to get everywhere.
结论
5等其他人完成本指南。
Tom Higdon
于01/15/13注册
409 声望
撰写一个指南
团队
Cal Poly, Team 18-35, Regan Winter 2013 Cal Poly, Team 18-35, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G35
5 名成员
创作了15篇指南
4条评论
pls help me to operate to restore my hp deskjet f4480, I removed last wk the catridges to refill but when i starting to put back the catriges, i cant move the catriges holder, give me some tips pls, hoping a lot, ty
rico timbol - 回复
please the drivers may be installed for using the scanner
sarvani valluru -
My daughter took out the ink cartridges on my F4480 hp desk jet and I don’t know how they go in correctly please help
Kelly Cook - 回复
Why don’t you answer my question I just don’t want to force them or rake it
Kelly Cook - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 33
总计 15,705
