跳转到主内容
HP Deskjet D1660 Gear Guard Replacement
你所需要的
  1. HP Deskjet D1660 Gear Guard Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Remove the back two 14.0 mm Torx #10 screws.
  2. HP Deskjet D1660 Gear Guard Replacement: 步骤 2 中的图像 1,1
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. HP Deskjet D1660 Gear Guard Replacement: 步骤 3 中的图像 1,1
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. HP Deskjet D1660 Gear Guard Replacement: 步骤 4 中的图像 1,3 HP Deskjet D1660 Gear Guard Replacement: 步骤 4 中的图像 2,3 HP Deskjet D1660 Gear Guard Replacement: 步骤 4 中的图像 3,3
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
  5. HP Deskjet D1660 Gear Guard Replacement, Ink Cartridge Rail: 步骤 5 中的图像 1,2 HP Deskjet D1660 Gear Guard Replacement, Ink Cartridge Rail: 步骤 5 中的图像 2,2
    • Remove the five 13.0 mm Torx #10 screws found on top of the frame.
    • Remove the four 9.0 mm Torx #10 smaller screws.
  6. HP Deskjet D1660 Gear Guard Replacement: 步骤 6 中的图像 1,2 HP Deskjet D1660 Gear Guard Replacement: 步骤 6 中的图像 2,2
    • Lift the rail carefully as a strip and motor will be connected to the bottom part of the printer.
    • Now detach the white strip and wires by gently lifting them up.
  7. HP Deskjet D1660 Gear Guard Replacement, Gear Guard: 步骤 7 中的图像 1,1
    • The gear guard will be located on the left side of the printer.
    • Grab the plastic guard and lift it up.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 1-41, Maness Winter 2014 Cal Poly, Team 1-41, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G41
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 1,217
