跳转到主内容
HP Deskjet 3522 Ink Cartridge Replacement
  1. HP Deskjet 3522 Ink Cartridge Replacement, Ink Cartridge: 步骤 1 中的图像 1,2 HP Deskjet 3522 Ink Cartridge Replacement, Ink Cartridge: 步骤 1 中的图像 2,2
    • Power printer on.
    • Lift up the lid to the printer using the notch on the right side of the printer to expose the ink cartridges.
  2. HP Deskjet 3522 Ink Cartridge Replacement: 步骤 2 中的图像 1,2 HP Deskjet 3522 Ink Cartridge Replacement: 步骤 2 中的图像 2,2
    • Press down gently on the front tab of the ink cartridge that needs replacing and then lift up.
  3. HP Deskjet 3522 Ink Cartridge Replacement: 步骤 3 中的图像 1,1
    • Make sure you have the correct model number of ink that needs to be replaced.
    • For the HP Deskjet 3522 the required ink is HP 564 (Regular or XL)
  4. HP Deskjet 3522 Ink Cartridge Replacement: 步骤 4 中的图像 1,2 HP Deskjet 3522 Ink Cartridge Replacement: 步骤 4 中的图像 2,2
    • Angle the new ink cartridge to the back and slide it into the slot. Press down gently on the head until you hear a soft click.
    • Close the lid and allow the printer to recalibrate itself.
结论
3等其他人完成本指南。
团队
USF Tampa, Team 1-30, Donnelly Fall 2014 USF Tampa, Team 1-30, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G30
1 名成员
创作了2篇指南
一条评论
These instructions were perfect to follow and complete.
walterawa1862 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 19
总计 2,488
