跳转到主内容
HP Deskjet 2624 Scanner Glass Replacement
你所需要的
  1. HP Deskjet 2624 Scanner Glass Replacement, Scanner Glass: 步骤 1 中的图像 1,1
    • Unplug all cords from the printer, and remove all the paper from the tray.
  2. HP Deskjet 2624 Scanner Glass Replacement: 步骤 2 中的图像 1,2 HP Deskjet 2624 Scanner Glass Replacement: 步骤 2 中的图像 2,2
    • Remove the four screws securing the scanner bed module to the printer body with a Torx T5 screwdriver.
  3. HP Deskjet 2624 Scanner Glass Replacement: 步骤 3 中的图像 1,1
    • Gently pry the scanner bed cover slightly off of the printer at the hinge.
    • Lifting the scanning bed cover to a 45 degree angle may make it easier to remove.
  4. HP Deskjet 2624 Scanner Glass Replacement: 步骤 4 中的图像 1,1
    • Lift up the scanner bed module and remove the two ribbon cables by pulling them straight out.
    • Set the printer body aside.
  5. HP Deskjet 2624 Scanner Glass Replacement: 步骤 5 中的图像 1,3 HP Deskjet 2624 Scanner Glass Replacement: 步骤 5 中的图像 2,3 HP Deskjet 2624 Scanner Glass Replacement: 步骤 5 中的图像 3,3
    • Separate the plastic halves of the scanner bed by gently pulling the tabs on the clips holding the halves together.
    • Pull the halves apart while undoing the clips to prevent plastic snapping.
  6. HP Deskjet 2624 Scanner Glass Replacement: 步骤 6 中的图像 1,2 HP Deskjet 2624 Scanner Glass Replacement: 步骤 6 中的图像 2,2
    • Remove the glass pane from the plastic shell by prying the tabs back that secure the glass, as well as peeling the adhesive apart slowly.
    • Glass edges can be sharp, handle glass and glass shards with gloves.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 36
总计 720
