跳转到主内容
HP Deskjet 2624 Motherboard Replacement
你所需要的
  1. HP Deskjet 2624 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Unplug all cords from the printer and remove the paper.
  2. HP Deskjet 2624 Motherboard Replacement: 步骤 2 中的图像 1,2 HP Deskjet 2624 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using the Torx T5 screwdriver, remove the four screws connecting the scanner bed module to the printer base.
  3. HP Deskjet 2624 Motherboard Replacement: 步骤 3 中的图像 1,2 HP Deskjet 2624 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Gently lift the scanner bed module slightly off of the printer base. Be sure to carefully unplug the ribbon cables before fully removing the scanner bed.
    • Unplug the ribbon cables by pulling them gently straight out of their plugs.
  4. HP Deskjet 2624 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the cables connected to the motherboard by gently pulling them straight out. Do not unplug the cables by pulling on the wires.
    • Unplug the last two ribbons connected to the motherboard by gently pulling them straight out.
    • Be sure to take note of where all plugs and ribbons are connected to the motherboard.
    • Remove the motherboard from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 494
