跳转到主内容
HP Deskjet 2624 Magnetic Strip Replacement
你所需要的
  1. HP Deskjet 2624 Magnetic Strip Replacement, Magnetic Strip: 步骤 1 中的图像 1,1
    • Unplug the printer and remove all paper from the input tray.
  2. HP Deskjet 2624 Magnetic Strip Replacement: 步骤 2 中的图像 1,2 HP Deskjet 2624 Magnetic Strip Replacement: 步骤 2 中的图像 2,2
    • Using the Torx T5 screwdriver, remove the four screws holding the scanner bed module to the printer base.
    • Slowly lift up the scanner bed slightly off the base.
    • Be sure to unplug the ribbons connecting the two parts by pulling them straight out of their plugs gently.
  3. HP Deskjet 2624 Magnetic Strip Replacement: 步骤 3 中的图像 1,2 HP Deskjet 2624 Magnetic Strip Replacement: 步骤 3 中的图像 2,2
    • Gently lift the scanner bed module slightly off of the printer base. Be sure to carefully unplug the ribbon cables before fully removing the scanner bed.
    • Unplug the ribbon cables by pulling them gently straight out of their plugs.
  4. HP Deskjet 2624 Magnetic Strip Replacement: 步骤 4 中的图像 1,3 HP Deskjet 2624 Magnetic Strip Replacement: 步骤 4 中的图像 2,3 HP Deskjet 2624 Magnetic Strip Replacement: 步骤 4 中的图像 3,3
    • Locate the magnetic strip found running straight through the ink cartridge carriage.
  5. HP Deskjet 2624 Magnetic Strip Replacement: 步骤 5 中的图像 1,3 HP Deskjet 2624 Magnetic Strip Replacement: 步骤 5 中的图像 2,3 HP Deskjet 2624 Magnetic Strip Replacement: 步骤 5 中的图像 3,3
    • To remove the strip, start by applying pressure to the silver connection located on the right hand side of the strip.
    • While applying pressure to the right hand side, push the strip off the left hand hook and pull it straight up.
    • Lift the strip vertically and unhook it from the silver strip.
    • When putting the strip back in, ensure that the arrow on the replacement faces to the right and downwards.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 514
