跳转到主内容
HP Deskjet 2624 Ink Cartridges Replacement
  1. HP Deskjet 2624 Ink Cartridges Replacement, Ink Cartridges: 步骤 1 中的图像 1,1
    • Unplug all of the cords from the printer and put paper into the input tray.
  2. HP Deskjet 2624 Ink Cartridges Replacement: 步骤 2 中的图像 1,3 HP Deskjet 2624 Ink Cartridges Replacement: 步骤 2 中的图像 2,3 HP Deskjet 2624 Ink Cartridges Replacement: 步骤 2 中的图像 3,3
    • Lower the output tray and the ink cartridge access door.
    • Lightly press forward on the cartridge to release it and then pull the cartridge straight out.
    • The slot on the left is the tri-color cartridge while the black cartridge is on the right.
  3. HP Deskjet 2624 Ink Cartridges Replacement: 步骤 3 中的图像 1,3 HP Deskjet 2624 Ink Cartridges Replacement: 步骤 3 中的图像 2,3 HP Deskjet 2624 Ink Cartridges Replacement: 步骤 3 中的图像 3,3
    • On the new cartridge, pull the colored tab to remove the plastic.
    • Hold the replacement with the nozzles toward the printer and insert it at an upward angle.
    • Push the cartridge forward until it snaps into place.
    • Repeat steps two and three if necessary.
结论
After completing this guide, don’t forget to plug in your HP Deskjet 2624 .
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 1,216
