跳转到主内容
HP Deskjet 1055 Ink Cartridge Replacement
你所需要的
  1. HP Deskjet 1055 Ink Cartridge Replacement, Ink Cartridge: 步骤 1 中的图像 1,1
    • Turn on the printer by pressing the power button.
  2. HP Deskjet 1055 Ink Cartridge Replacement: 步骤 2 中的图像 1,2 HP Deskjet 1055 Ink Cartridge Replacement: 步骤 2 中的图像 2,2
    • Place your index finger in the opening on the front of the printer (right side below scanner/copier) and pull the door down.
    • Pull down on the tab that lies in the middle of the newly-exposed gray cover.
  3. HP Deskjet 1055 Ink Cartridge Replacement: 步骤 3 中的图像 1,1
    • The tri-color cartridge sits on the left side; the black cartridge sits on the right.
    • Grab the cartridge from the top and bottom and pull down until it clicks.
    • Pull out the freed cartridge.
  4. HP Deskjet 1055 Ink Cartridge Replacement: 步骤 4 中的图像 1,3 HP Deskjet 1055 Ink Cartridge Replacement: 步骤 4 中的图像 2,3 HP Deskjet 1055 Ink Cartridge Replacement: 步骤 4 中的图像 3,3
    • Take the replacement cartridge out of its packaging and pull off the plastic tab.
    • Do not touch the electrical contacts or ink nozzles. Touching may cause malfunctions.
    • Hold the cartridge on both sides with the title sticker facing upwards.
  5. HP Deskjet 1055 Ink Cartridge Replacement: 步骤 5 中的图像 1,2 HP Deskjet 1055 Ink Cartridge Replacement: 步骤 5 中的图像 2,2
    • Slide the cartridge directly into open slot (tri-color on the left, black on the right).
    • Push it forward until you hear it snap.
  6. HP Deskjet 1055 Ink Cartridge Replacement: 步骤 6 中的图像 1,1
    • Close the gray access door.
  7. HP Deskjet 1055 Ink Cartridge Replacement: 步骤 7 中的图像 1,2 HP Deskjet 1055 Ink Cartridge Replacement: 步骤 7 中的图像 2,2
    • Wait 30 seconds for the alignment page to print.
    • Open up the scanner lid and place the alignment page face-down in the right-front corner of the glass.
    • Close the lid.
  8. HP Deskjet 1055 Ink Cartridge Replacement: 步骤 8 中的图像 1,1
    • Press the color copy button to begin scan.
    • Wait until the power button stops blinking.
结论
When the power button stops blinking, your can now use your printer.
4等其他人完成本指南。
Daniel
于10/06/12注册
314 声望
创作了2篇指南
团队
Cal Poly, Team 9-18, Amido Fall 2012 Cal Poly, Team 9-18, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G18
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 24
总计 15,992
