跳转到主内容
加入维修社区 - 创建账户
HP Deskjet 1055 Buttons Replacement
你所需要的
  1. HP Deskjet 1055 Buttons Replacement, Buttons: 步骤 1 中的图像 1,1
    • Press your thumb down on the center of the button plate located on the left side of the printer.
    • Hook your fingers underneath the front edge of the button plate and pull upwards making sure to keep pressure on the middle of the plate with your thumb.
    • When pulling up the front cover make sure to keep your thumb pressed firmly on the cover plate and bend up the front. Not doing so will result in breaking the tab that holds the back of the plate to the printer.
    询问修复机器人
    添加评论
  2. HP Deskjet 1055 Buttons Replacement: 步骤 2 中的图像 1,3 HP Deskjet 1055 Buttons Replacement: 步骤 2 中的图像 2,3 HP Deskjet 1055 Buttons Replacement: 步骤 2 中的图像 3,3
    • Once the front of the plate is loose, lift it up a few inches making sure to hold the back (paper feeding side) of the plate down.
    • Slide the plate towards the back of the printer and then lift up on the back of the plate.
    • The plate should now be disconnected from the tabs on the printer.
    询问修复机器人
    添加评论
  3. HP Deskjet 1055 Buttons Replacement: 步骤 3 中的图像 1,3 HP Deskjet 1055 Buttons Replacement: 步骤 3 中的图像 2,3 HP Deskjet 1055 Buttons Replacement: 步骤 3 中的图像 3,3
    • Turn the plate over to reveal the white strip of connecting tape that connects the plate to the printer.
    • Find where the tape is connected to the green button circuit board (Location circled in red)
    • Place two fingers on the tape right where it connects to the plate and gently pull the tape out of the circuit board.
    询问修复机器人
    添加评论
  4. HP Deskjet 1055 Buttons Replacement: 步骤 4 中的图像 1,1
    • Place the plate down on a flat surface with the button circuit board facing up.
    • Remove the three(3) T-10 Torx Screws from the circuit board.
    询问修复机器人
    添加评论
  5. HP Deskjet 1055 Buttons Replacement: 步骤 5 中的图像 1,1
    • Lift the button circuit board up and off of the button plate
    询问修复机器人
    添加评论
  6. HP Deskjet 1055 Buttons Replacement: 步骤 6 中的图像 1,2 HP Deskjet 1055 Buttons Replacement: 步骤 6 中的图像 2,2
    • After Removing the circuit board you will be able to see the backside of the set of function buttons.
    • Lightly push each of the six tabs away from the clips holding them in.
    • Make sure to unclip all the tabs before pushing the buttons out of the plate. All the buttons are connected as a set and trying to remove them one at a time will result in them breaking.
    • Once all of the tabs are loose from their clips, push the set of buttons down and out of the button plate.
    询问修复机器人
    添加评论
  7. HP Deskjet 1055 Buttons Replacement: 步骤 7 中的图像 1,1
    • The power button is not clipped in and should easily slide off of the plate once the button circuit board is removed.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Matt
于10/09/12注册
88 声望
创作了2篇指南
团队
Cal Poly, Team 9-18, Amido Fall 2012 Cal Poly, Team 9-18, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G18
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 34
总计 2,507
