跳转到主内容
HP Deskjet 1000 J110a Power Button Replacement
你所需要的
  1. HP Deskjet 1000 J110a Power Button Replacement, Cover Removal: 步骤 1 中的图像 1,3 HP Deskjet 1000 J110a Power Button Replacement, Cover Removal: 步骤 1 中的图像 2,3 HP Deskjet 1000 J110a Power Button Replacement, Cover Removal: 步骤 1 中的图像 3,3
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. HP Deskjet 1000 J110a Power Button Replacement: 步骤 2 中的图像 1,3 HP Deskjet 1000 J110a Power Button Replacement: 步骤 2 中的图像 2,3 HP Deskjet 1000 J110a Power Button Replacement: 步骤 2 中的图像 3,3
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. HP Deskjet 1000 J110a Power Button Replacement: 步骤 3 中的图像 1,1
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
  4. HP Deskjet 1000 J110a Power Button Replacement, Power Button: 步骤 4 中的图像 1,3 HP Deskjet 1000 J110a Power Button Replacement, Power Button: 步骤 4 中的图像 2,3 HP Deskjet 1000 J110a Power Button Replacement, Power Button: 步骤 4 中的图像 3,3
    • Carefully hold the small clip back to release the button arm.
    • Once the arm is unclipped, gently lift and pull the button until it disconnects at the hinge slot.
    • Replace the old power button with a new one.
结论
Colin Tourjee
于01/29/18注册
632 声望
创作了4篇指南
团队
USF Tampa, Team S5-G3, Passmore Spring 2018 USF Tampa, Team S5-G3, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S5G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 9
总计 374
