跳转到主内容
HP Deskjet 1000 J110a Plug Ports Replacement
你所需要的
  1. HP Deskjet 1000 J110a Plug Ports Replacement, Cover Removal: 步骤 1 中的图像 1,3 HP Deskjet 1000 J110a Plug Ports Replacement, Cover Removal: 步骤 1 中的图像 2,3 HP Deskjet 1000 J110a Plug Ports Replacement, Cover Removal: 步骤 1 中的图像 3,3
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. HP Deskjet 1000 J110a Plug Ports Replacement: 步骤 2 中的图像 1,3 HP Deskjet 1000 J110a Plug Ports Replacement: 步骤 2 中的图像 2,3 HP Deskjet 1000 J110a Plug Ports Replacement: 步骤 2 中的图像 3,3
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. HP Deskjet 1000 J110a Plug Ports Replacement: 步骤 3 中的图像 1,1
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
  4. HP Deskjet 1000 J110a Plug Ports Replacement, Plug Ports: 步骤 4 中的图像 1,3 HP Deskjet 1000 J110a Plug Ports Replacement, Plug Ports: 步骤 4 中的图像 2,3 HP Deskjet 1000 J110a Plug Ports Replacement, Plug Ports: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Locate and remove the two flat ribbon connectors which connect the circuit board to the other printer components.
    • Remove each connector using tweezers if it is too difficult to remove them by hand.
  5. HP Deskjet 1000 J110a Plug Ports Replacement: 步骤 5 中的图像 1,2 HP Deskjet 1000 J110a Plug Ports Replacement: 步骤 5 中的图像 2,2
    • Locate and remove the three multicolored wire connectors which connect the circuit board to the other printer components.
    • Remove each connector by hand, as shown. You can use tweezers if it is too difficult to remove them by hand.
  6. HP Deskjet 1000 J110a Plug Ports Replacement: 步骤 6 中的图像 1,3 HP Deskjet 1000 J110a Plug Ports Replacement: 步骤 6 中的图像 2,3 HP Deskjet 1000 J110a Plug Ports Replacement: 步骤 6 中的图像 3,3
    • Remove the top two 13mm screws using a screwdriver with the T10 torx bit.
    • Remove the bottom 9mm screw using a screwdriver with the T10 torx bit, and remove the plug port circuit board.
结论
另外一个人完成了本指南。
Chris Perez
于01/29/18注册
295 声望
创作了2篇指南
团队
USF Tampa, Team S5-G3, Passmore Spring 2018 USF Tampa, Team S5-G3, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S5G3
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 697
