简介
The plug ports are soldered onto the circuit board, so this is more of a circuit board replacement. Be careful when handling electronic circuit boards to avoid damaging the components and to avoid electric shock.
你所需要的
Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
在这个步骤中使用的工具:Tweezers$4.99
Locate and remove the two flat ribbon connectors which connect the circuit board to the other printer components.
另外一个人完成了本指南。
